A quick review and brilliant blog post by Oracle ACE Dirk Nachbar
How about yours? Is there anyone who used "User Defined JMX Metric Actions" on WLSDM for WebLogic console?
A quick look on WLSDM for WebLogic Server
WLSDM (WL Smart Dashboard & Monitoring) was already mentioned by some people within the Oracle WebLogic Community.
The WLSDM tool is a Console extension with which you can monitor your Oracle WebLogic Server environment. But its not only a pure monitoring tool, its more than this, it provides on top even Notifications and Alarms for metrics.
Current release for WLSDM is 2.3.1 which also comes with Oracle SOA Support :-)
The installation is really straight forward as described in the installation document from the WLSDM, but the given 1 minute deploy time is a bit optimistic :-) its more 5 minutes, but this is still impressive how quick you can setup WLSDM :-) Just follow the instructions for the installation, after you start the WLSDM Dashboard, the configuration assistant will guide you through the necessary configuration and your Monitoring and Notification/Alarm System is ready to use.
WLSDM comes is real Dashboard Style with provides you several views on your WebLogic Server environment.
General Health Overview Dashboard:
Image of Health Dashoard
Read the complete blog post by Oracle ACE Dirk Nachbar
