    JVM Monitoring Error
    jvm wlsdm oracle
    6
    5576
    • wlcommunityusers
      wlcommunityusers last edited by
      We have an issue trying to configure JVM monitoring in one of the domains.
      As it shows in the screen , the problem appears because of -Xmanagement argument.
      The entire argument we have configured is: -Xmanagement:class=com.bea.misc.ConfigurableJMXAgent.
      The problem is there’s another team using it to connect through RMI ports.
      Please, can you recommend me an alternative solution?
      Thanks in advance,
      Regards,
      Community Users Case Notes (Diary)
      1 Reply Last reply Reply Quote 0
      • wlsdmsupport
        WLSDM Support last edited by
        Which WebLogic and java version are you using?
        Kind Regards.
        • wlcommunityusers
          We are using Java 6
          weblogic@LNKD851:~> /opt/bea/jrockit-jdk/bin/java -version
          java version “1.6.0_45”
          Java™ SE Runtime Environment (build 1.6.0_45-b06)
          Oracle JRockit® (build R28.2.7-7-155314-1.6.0_45-20130329-0641-linux-x86_64, compiled mode)
          Regards,
          • wlsdmsupport
            Please add -Djavax.management.builder.initial=weblogic.management.jmx.mbeanserver.WLSMBeanServerBuilder JVM argument to the relevant servers and restart the servers.
            If the problem still persists after adding above JVM parameter; please send “$DOMAIN_HOME/WLSDM/logs” as zip file.
            Kind Regards.
            • wlcommunityusers
              Once I added the arguments recommended by you I could collect JVM information and everything looks good. (agents, managed servers, etc)
              There is just one thing I couldn’t solve, in the JVM information section I still have the same warning message regarding to -Xmanagement argument.
              In the other hand, I’m trying to configure a script to be executed once I have a stuck thread alarm.
              Is it possible to do that?
              Thank you very much,
              Regards,
              • wlsdmsupport
                On the other hand, I’m trying to configure a script to be executed once I have a stuck thread alarm.
                Yes, you can set alarm to scripts. Please check below tutorials.
                OracleDB ACTIVE/INACTIVE Sessions monitoring on WebLogic: https://youtu.be/XjBz6zlKstM
                Generic DevOps Disk Usage MBean Tutorial: https://youtu.be/OYkPEpxF66M
                Kind Regards
