    SOLVED Domain Not Added for Monitoring
    6
    5248
    • wlcommunityusers
      wlcommunityusers last edited by
      I am trying to add new domains in WLSDM OPC for monitoring, I go through the steps, but it doesn’t add them:
      Can you tell me which is the correct procedure?
      Regards.
      Community Users Case Notes (Diary)
      can.sahin-wlsdmteam 1 Reply Last reply Reply Quote 0
      • can.sahin-wlsdmteam
        Can Sahin - WLSDM Team @wlcommunityusers last edited by
        @wlcommunityusers
        Please delete token and host property in WLSDM then restart WLSDM Domain’s admin server.
        When you complete these steps; WLSDM will not be registered any more in WLSDM. After these; please register domain again in WL-OPC.
        Kind Regards,
        WLSDM Support Team
        https://community.wlsdm.com
        Can Şahin
        wlcommunityusers 1 Reply Last reply Reply Quote 0
          @wlcommunityusers
          When you register WLSDM domain to WL-OPC once, WL-OPC keeps that domain info.
          You need to select “Overwrite” option for reregistration. So, please select “Overwrite” option and try to register domain again?
          Kind Regards,
          WLSDM Support Team
          Can Şahin
          • wlcommunityusers
            wlcommunityusers @can.sahin-wlsdmteam last edited by
            @can-sahin-wlsdmteam
            I have done the indicated, however you have not added the domain.
            Regards.
              @wlcommunityusers
              Kind Regards,
              WLSDM Support Team
              Can Şahin
              • wlcommunityusers
                Thanks, now I could add the domain:
                Regards.
                  @wlcommunityusers
                  We fixed this issue in v3.9.2. If you upgrade the WLSDM domain v3.7.2 to v3.9.2 you will not face this issue any more.
                  Kind Regards,
                  WLSDM Support Team
                  Can Şahin
