    SOLVED WLSDM not able to read Weblogic Domain
    4
    3739
    • V
      valeC last edited by valeC
      I successfully installed WLSDM in my dev environment. I get the relevant messages both in the admin server log and managed server log hosted in the same machine:
      MS:
      <Sat Oct 16 10:46:30 CEST 2021> <Info> <WLSDM> <BEA-000000> <VOPM.WLSDM.Backend Starting...>
      <Sat Oct 16 10:46:35 CEST 2021> <Info> <WLSDM> <BEA-000000> <WLSDM agent loaded successfully. Version: v3.9.2-b4318>
      <Sat Oct 16 10:47:16 CEST 2021> <Info> <WLSDM> <BEA-000000> <RJVM operation is bound in the registry with the name vopm_agent_remote_operation.>
      <Sat Oct 16 10:47:16 CEST 2021> <Info> <WLSDM> <BEA-000000> <RJVM operation is bound in the registry with the name wlsdm_agent_remote_operation.>
      Admin:
      <Oct 16, 2021 11:06:52 AM CEST> <Info> <WLSDM> <BEA-000000> <Initializing the WLSDM properties...>
      <Oct 16, 2021 11:07:21 AM CEST> <Info> <WLSDM> <BEA-000000> <Setting-up the WLSDM Database...>
      <Oct 16, 2021 11:07:40 AM CEST> <Info> <WLSDM> <BEA-000000> <WLSDM console deployed successfully. Version: v3.9.2-b4318>
      <Oct 16, 2021 11:07:40 AM CEST> <Info> <WLSDM> <BEA-000000> <WLSDM garbage collection monitoring initialized successfully.>
      <Oct 16, 2021 11:07:40 AM CEST> <Info> <WLSDM> <BEA-000000> <WLSDM metric monitoring initialized successfully.>
      <Oct 16, 2021 11:07:40 AM CEST> <Info> <WLSDM> <BEA-000000> <WLSDM health monitoring initialized successfully.>
      <Oct 16, 2021 11:07:40 AM CEST> <Info> <WLSDM> <BEA-000000> <WLSDM performance monitoring initialized successfully.>
      <Oct 16, 2021 11:07:40 AM CEST> <Info> <WLSDM> <BEA-000000> <WLSDM back-end monitoring initialized successfully.>
      <Oct 16, 2021 11:07:40 AM CEST> <Info> <WLSDM> <BEA-000000> <WLSDM data archiver initialized successfully.>
      <Oct 16, 2021 11:07:40 AM CEST> <Info> <WLSDM> <BEA-000000> <WLSDM custom DevOps MBean handler initialized successfully.>
      <Oct 16, 2021 11:07:40 AM CEST> <Info> <WLSDM> <BEA-000000> <WLSDM job scheduler initialized successfully.>
      I then tried to go through the wizard in WLSDM console and got a SEVERE error while trying to read Weblogic domain. This is the excerpt from the WLSDM log:
      ####<Oct 16, 2021 11:18:34 AM CEST><SEVERE><WLSDM><BEA-000000><null
      java.lang.NullPointerException
              at com.wlsdm.Q.K.getDeployedJMSServers(MetricUtilities.java:1326)
              at com.wlsdm.frontend.provider.WA.getJMSServerList(MetricsData.java:489)
              at com.wlsdm.P.J.E(Data.java:11019)
              at com.wlsdm.P.J.A(Data.java:336)
              at com.wlsdm.P.J.doGet(Data.java:171)
              at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
              at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
      From the WL console I am able to see that the JMS server targeted to the running MS is healthy.
      Wizard does not proceed and is stuck at reading Weblogic Domain.
      wlsdmsupport 2 Replies Last reply Reply Quote 0
      • wlsdmsupport
        WLSDM Support @valeC last edited by
        @valec
        We are aware of this issue. This bug will be fixed in the next version.
        Regards.
        1 Reply Last reply Reply Quote 0
        • wlsdmsupport
          @valec
          We have reproduced the problem that you are experiencing in our LAB environment and published a fix version. You can access the fix version using the URL below.
          Build number: b4320
          URL: https://wlsdm.com/downloads/release_candidate/wlsdm/rc/wlsdm.v3.9.2.zip
          Regards.
          V 1 Reply Last reply Reply Quote 0
          • V
            valeC @wlsdmsupport last edited by
            @wlsdmsupport Hi, I was able to run and configure WLSDM smoothly.
            Thank you very much for the excellent and swift work!
            1 Reply Last reply Reply Quote 1
