    SOLVED WLSDM for AdminServer
    4
    3874
    • Prakash_2006
      Prakash_2006 last edited by
      why wlsdm is not intended to monitor AdminServer
      fevzi.korkutata-wlsdmteam 1 Reply Last reply Reply Quote 0
      • fevzi.korkutata-wlsdmteam
        M.Fevzi Korkutata - WLSDM Team @Prakash_2006 last edited by
        @prakash_2006
        It seems incompatible Java version error. Please confirm the correct Java version by following below document?
        Download and install the latest JDK 1.8.x compatible with your OS platform
        https://wlsdm.com/wl-opc/docs/readme#prerequisites
        M.Fevzi Korkutata
        WLSDM Product Manager
          @prakash_2006 said in WLSDM for AdminServer:
          WLSDM able to monitor AdminServer. Please find the documentation here.
          https://wlsdm.com/docs/README#X.MonitoringAdminServer&WL-OPC
          You can monitor AdminServer via WLSDM standalone process or WL-OPC. We’re recommending to use WL-OPC for monitoring WebLogic Admin server. https://wlsdm.com/wl-opc
          Kind Regards…
          M.Fevzi Korkutata
          Prakash_2006 1 Reply Last reply Reply Quote 0
          • Prakash_2006
            Prakash_2006 @fevzi.korkutata-wlsdmteam last edited by
            @fevzi-korkutata-wlsdmteam
            I am trying t start the opc.bat and it says the below error:-
            C:\Users\praka\Downloads\Weblogic14.1.2\wl-opc\bin>opc.bat start
            The application failed with the below error:-
            2025-01-17 12:55:07.079 INFO 21512 — [ main] com.wlsdm.opc.WLOPC : Starting WLOPC vv1.9.2 on Prakash with PID 21512 (C:\Users\praka\Downloads\Weblogic14.1.2\wl-opc\bin\wl-opc.v1.9.2.jar started by praka in C:\Users\praka\Downloads\Weblogic14.1.2\wl-opc\bin)
            2025-01-17 12:55:07.082 INFO 21512 — [ main] com.wlsdm.opc.WLOPC : No active profile set, falling back to default profiles: default
            2025-01-17 12:55:07.179 INFO 21512 — [ main] ConfigServletWebServerApplicationContext : Refreshing org.springframework.boot.web.servlet.context.AnnotationConfigServletWebServerApplicationContext@40317ba2: startup date [Fri Jan 17 12:55:07 CST 2025]; root of context hierarchy
            2025-01-17 12:55:09.209 ERROR 21512 — [ main] o.s.boot.SpringApplication : Application run failed
            java.lang.IllegalStateException: Cannot load configuration class: com.wlsdm.opc.WLOPC
            at org.springframework.context.annotation.ConfigurationClassPostProcessor.enhanceConfigurationClasses(ConfigurationClassPostProcessor.java:414) ~[spring-context-5.0.5.RELEASE.jar!/:5.0.5.RELEASE]
            at org.springframework.context.annotation.ConfigurationClassPostProcessor.postProcessBeanFactory(ConfigurationClassPostProcessor.java:254) ~[spring-context-5.0.5.RELEASE.jar!/:5.0.5.RELEASE]
            at org.springframework.context.support.PostProcessorRegistrationDelegate.invokeBeanFactoryPostProcessors(PostProcessorRegistrationDelegate.java:284) ~[spring-context-5.0.5.RELEASE.jar!/:5.0.5.RELEASE]
            at org.springframework.context.support.PostProcessorRegistrationDelegate.invokeBeanFactoryPostProcessors(PostProcessorRegistrationDelegate.java:128) ~[spring-context-5.0.5.RELEASE.jar!/:5.0.5.RELEASE]
            at org.springframework.context.support.AbstractApplicationContext.invokeBeanFactoryPostProcessors(AbstractApplicationContext.java:694) ~[spring-context-5.0.5.RELEASE.jar!/:5.0.5.RELEASE]
            at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:532) ~[spring-context-5.0.5.RELEASE.jar!/:5.0.5.RELEASE]
            at org.springframework.boot.web.servlet.context.ServletWebServerApplicationContext.refresh(ServletWebServerApplicationContext.java:140) ~[spring-boot-2.0.1.RELEASE.jar!/:2.0.1.RELEASE]
            at org.springframework.boot.SpringApplication.refresh(SpringApplication.java:759) ~[spring-boot-2.0.1.RELEASE.jar!/:2.0.1.RELEASE]
            at org.springframework.boot.SpringApplication.refreshContext(SpringApplication.java:395) ~[spring-boot-2.0.1.RELEASE.jar!/:2.0.1.RELEASE]
            at org.springframework.boot.SpringApplication.run(SpringApplication.java:327) ~[spring-boot-2.0.1.RELEASE.jar!/:2.0.1.RELEASE]
            at org.springframework.boot.SpringApplication.run(SpringApplication.java:1255) ~[spring-boot-2.0.1.RELEASE.jar!/:2.0.1.RELEASE]
            at org.springframework.boot.SpringApplication.run(SpringApplication.java:1243) ~[spring-boot-2.0.1.RELEASE.jar!/:2.0.1.RELEASE]
            at com.wlsdm.opc.WLOPC.main(WLOPC.java:175) ~[classes!/:v1.9.2]
            at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:na]
            at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77) ~[na:na]
            at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:na]
            at java.base/java.lang.reflect.Method.invoke(Method.java:568) ~[na:na]
            at org.springframework.boot.loader.MainMethodRunner.run(MainMethodRunner.java:48) ~[wl-opc.v1.9.2.jar:v1.9.2]
            at org.springframework.boot.loader.Launcher.launch(Launcher.java:87) ~[wl-opc.v1.9.2.jar:v1.9.2]
            at org.springframework.boot.loader.Launcher.launch(Launcher.java:50) ~[wl-opc.v1.9.2.jar:v1.9.2]
            at org.springframework.boot.loader.JarLauncher.main(JarLauncher.java:51) ~[wl-opc.v1.9.2.jar:v1.9.2]
            Caused by: java.lang.ExceptionInInitializerError: null
            at org.springframework.context.annotation.ConfigurationClassEnhancer.newEnhancer(ConfigurationClassEnhancer.java:122) ~[spring-context-5.0.5.RELEASE.jar!/:5.0.5.RELEASE]
            at org.springframework.context.annotation.ConfigurationClassEnhancer.enhance(ConfigurationClassEnhancer.java:110) ~[spring-context-5.0.5.RELEASE.jar!/:5.0.5.RELEASE]
            at org.springframework.context.annotation.ConfigurationClassPostProcessor.enhanceConfigurationClasses(ConfigurationClassPostProcessor.java:403) ~[spring-context-5.0.5.RELEASE.jar!/:5.0.5.RELEASE]
            … 20 common frames omitted
            Caused by: org.springframework.cglib.core.CodeGenerationException: java.lang.reflect.InaccessibleObjectException–>Unable to make protected final java.lang.Class java.lang.ClassLoader.defineClass(java.lang.String,byte[],int,int,java.security.ProtectionDomain) throws java.lang.ClassFormatError accessible: module java.base does not “opens java.lang” to unnamed module @60438a68
            at org.springframework.cglib.core.ReflectUtils.defineClass(ReflectUtils.java:464) ~[spring-core-5.0.5.RELEASE.jar!/:5.0.5.RELEASE]
            at org.springframework.cglib.core.AbstractClassGenerator.generate(AbstractClassGenerator.java:336) ~[spring-core-5.0.5.RELEASE.jar!/:5.0.5.RELEASE]
            at org.springframework.cglib.core.AbstractClassGenerator$ClassLoaderData$3.apply(AbstractClassGenerator.java:93) ~[spring-core-5.0.5.RELEASE.jar!/:5.0.5.RELEASE]
            at org.springframework.cglib.core.AbstractClassGenerator$ClassLoaderData$3.apply(AbstractClassGenerator.java:91) ~[spring-core-5.0.5.RELEASE.jar!/:5.0.5.RELEASE]
            at org.springframework.cglib.core.internal.LoadingCache$2.call(LoadingCache.java:54) ~[spring-core-5.0.5.RELEASE.jar!/:5.0.5.RELEASE]
            at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264) ~[na:na]
            at org.springframework.cglib.core.internal.LoadingCache.createEntry(LoadingCache.java:61) ~[spring-core-5.0.5.RELEASE.jar!/:5.0.5.RELEASE]
            at org.springframework.cglib.core.internal.LoadingCache.get(LoadingCache.java:34) ~[spring-core-5.0.5.RELEASE.jar!/:5.0.5.RELEASE]
            at org.springframework.cglib.core.AbstractClassGenerator$ClassLoaderData.get(AbstractClassGenerator.java:116) ~[spring-core-5.0.5.RELEASE.jar!/:5.0.5.RELEASE]
            at org.springframework.cglib.core.AbstractClassGenerator.create(AbstractClassGenerator.java:291) ~[spring-core-5.0.5.RELEASE.jar!/:5.0.5.RELEASE]
            at org.springframework.cglib.core.KeyFactory$Generator.create(KeyFactory.java:221) ~[spring-core-5.0.5.RELEASE.jar!/:5.0.5.RELEASE]
            at org.springframework.cglib.core.KeyFactory.create(KeyFactory.java:174) ~[spring-core-5.0.5.RELEASE.jar!/:5.0.5.RELEASE]
            at org.springframework.cglib.core.KeyFactory.create(KeyFactory.java:153) ~[spring-core-5.0.5.RELEASE.jar!/:5.0.5.RELEASE]
            at org.springframework.cglib.proxy.Enhancer.(Enhancer.java:73) ~[spring-core-5.0.5.RELEASE.jar!/:5.0.5.RELEASE]
            … 23 common frames omitted
            Caused by: java.lang.reflect.InaccessibleObjectException: Unable to make protected final java.lang.Class java.lang.ClassLoader.defineClass(java.lang.String,byte[],int,int,java.security.ProtectionDomain) throws java.lang.ClassFormatError accessible: module java.base does not “opens java.lang” to unnamed module @60438a68
            at java.base/java.lang.reflect.AccessibleObject.checkCanSetAccessible(AccessibleObject.java:354) ~[na:na]
            at java.base/java.lang.reflect.AccessibleObject.checkCanSetAccessible(AccessibleObject.java:297) ~[na:na]
            at java.base/java.lang.reflect.Method.checkCanSetAccessible(Method.java:199) ~[na:na]
            at java.base/java.lang.reflect.Method.setAccessible(Method.java:193) ~[na:na]
            at org.springframework.cglib.core.ReflectUtils$1.run(ReflectUtils.java:61) ~[spring-core-5.0.5.RELEASE.jar!/:5.0.5.RELEASE]
            at java.base/java.security.AccessController.doPrivileged(AccessController.java:569) ~[na:na]
            at org.springframework.cglib.core.ReflectUtils.(ReflectUtils.java:52) ~[spring-core-5.0.5.RELEASE.jar!/:5.0.5.RELEASE]
            at org.springframework.cglib.core.KeyFactory$Generator.generateClass(KeyFactory.java:243) ~[spring-core-5.0.5.RELEASE.jar!/:5.0.5.RELEASE]
            at org.springframework.cglib.core.DefaultGeneratorStrategy.generate(DefaultGeneratorStrategy.java:25) ~[spring-core-5.0.5.RELEASE.jar!/:5.0.5.RELEASE]
            at org.springframework.cglib.core.AbstractClassGenerator.generate(AbstractClassGenerator.java:329) ~[spring-core-5.0.5.RELEASE.jar!/:5.0.5.RELEASE]
            … 35 common frames omitted
            2025-01-17 12:55:09.213 INFO 21512 — [ main] ConfigServletWebServerApplicationContext : Closing org.springframework.boot.web.servlet.context.AnnotationConfigServletWebServerApplicationContext@40317ba2: startup date [Fri Jan 17 12:55:07 CST 2025]; root of context hierarchy
            Regards,
            Prakash.
              @prakash_2006
              M.Fevzi Korkutata
