    SOLVED WL-OPC Connection with WLSDM Over https
    wlsdm wl-opc
    23
    18615
    • wlcommunityusers
      wlcommunityusers last edited by
      I’m trying to configure WL-OPC with my WLSDMs domains over https (I checked connection through telnet and it works ok) but it seems OPC doesn’t reach targets over https, just over http.
      Could you please help me with this?
      Regards.
      Community Users Case Notes (Diary)
      wlsdmsupport 1 Reply Last reply Reply Quote 0
      • wlcommunityusers
        wlcommunityusers @wlcommunityusers last edited by
        @wlcommunityusers
        Finally, I found the solution.
        I changed java.security in WL-OPC disabling jdk.tls.disabledAlgorithms like this:
        And then I removed all the arguments in JAVA_OPTIONS to default OPC installation.
        I restarted OPC and I could add the domains without any problem.
        Regards.
        • wlsdmsupport
          WLSDM Support @wlcommunityusers last edited by
          @wlcommunityusers
          When you enabled SSL WL-OPC, you are facing WL-OPC to WLSDM connecting issues?
          Could you send “OPC_HOME\bin\WLOPC\logs\wl-opc.log” ?
          Regards
          • wlsdmsupport
            WLSDM Support @wlsdmsupport last edited by can.sahin-wlsdmteam
            @can-sahin-wlsdmteam
            There is missing certificate configuration. You need to add certificate for SSL WL-OPC.
            Could you check attached configuration for below error please?
            "Caused by: java.io.FileNotFoundException: /u01/opc/bin/keystore.p12 (No such file or directory)"
            wlcommunityusers 1 Reply Last reply Reply Quote 0
            • wlcommunityusers
              wlcommunityusers @wlsdmsupport last edited by
              I added certificates to WL-OPC and WLSDM is still not reachable.
              • wlsdmsupport
                @wlcommunityusers
                Can you explain with screenshots what you want to do and whats is the issue?
                Regards.
                • wlcommunityusers
                  wlcommunityusers @wlsdmsupport last edited by can.sahin-wlsdmteam
                  This is what happened when I try to register a new domain from WL-OPC (http or https) to WLSDM/Weblogic console (over https)
                  This is what I have in log files
                  Telnet test:
                  From WLSDM side
                  URL: https://…:9002/console/WLSDM/config/system
                  This is a strange thing I see from tcpdump in WLSDM server
                  OPC is trying to connect to WLSDM through http instead https
                  This is the configuration from WLSDM to OPC
                  • wlsdmsupport
                    @wlcommunityusers
                    I understand your case and you want HTTPS communication. Why you are not considering to add WebLogic admin’s HTTP port? When you add as https port; you need to also take care of adding trust certificates on both side?
                    Thank you for your communication.
                    Kind Regards.
                    • wlcommunityusers
                      Thanks for your feedback.
                      I understand we will need to create certificates for https communication between OPC and WLS AdminServers but it’s our default procedure for any WebLogic managed server or AdminServer.
                      Thank you very much for your update.
                      Regards,
                      • wlsdmsupport
                        @wlcommunityusers
                        In WL-OPC https and http traffic both can be enabled at the same time. The WLSDM & WL-OPC traffic based on token and without a registered token WLSDM cannot publish to WL-OPC. Currently we are supporting both https and http.
                        As a result, we fixed the problem and you are going to able to add your https and t3s domains. On the other hand, are you prefer https traffic from WLSDM to WL-OPC, too? Our default setting is http from WLSDM to WL-OPC but you can disable HTTP on WL-OPC setting. Take below screen capture as a reference.
                        We are waiting your reply back.
                        Regards.
                        • wlsdmsupport
                          • wlcommunityusers
                            For now, it’s ok having http traffic from WLSDM to WL-OPC, by the way, it would be great to have both options in future releases.
                            Regards.
                            • wlsdmsupport
                              WLSDM Support @wlcommunityusers last edited by can.sahin-wlsdmteam
                              @wlcommunityusers
                              Hi ,
                              You can follow below path to setup your HTTPS traffic. If any help needed please let us know.
                              1. Generate keystore wlopc.p12
                              keytool -genkeypair -alias wlopc -keyalg RSA -keysize 2048 -storetype PKCS12 -keystore wlopc.p12 -validity 3650
                              1. Update WL-OPC settings as below screen capture.
                              2. Export & download WL-OPC’s certificate from browser (Use firefox and the output is volthread-technology.pem)
                              3. Convert pem format to der format.
                              openssl x509 -outform der -in volthread-technology.pem  -out volthread-technology.der
                              1. Then import to WebLogic AdminServer’s JKS file, set WebLogic AdminServer’s HostName Verification to NONE and finally restart admin server.
                              keytool -import -alias volthread -keystore DemoTrust.jks -file volthread-technology.der
                              Anymore WLSDM and WL-OPC works as HTTPS
                              • wlcommunityusers
                                wlcommunityusers @wlsdmsupport last edited by fevzi.korkutata-wlsdmteam
                                By the way, when I try to add the domain from WL-OPC I get this.
                                Handshake failed: TLSv1.3, error = No appropriate protocol (protocol is disabled or cipher suites are inappropriate)
                                Handshake failed: TLSv1.2, error = The server selected protocol version TLS10 is not accepted by client preferences [TLS12]
                                Handshake failed: TLSv1.1, error = No appropriate protocol (protocol is disabled or cipher suites are inappropriate)
                                Handshake failed: TLSv1, error = No appropriate protocol (protocol is disabled or cipher suites are inappropriate)
                                It looks like TLS version is not supported.
                                Regards.
                                • wlsdmsupport
                                  @wlcommunityusers
                                  Please increase the timeout and re-try again. This time remember to select “Overwrite” option on WL-OPC.
                                  Then let me know the result?
                                  • wlcommunityusers
                                    I did the changes:
                                    • wlcommunityusers
                                      @wlcommunityusers
                                      Some additional information:
                                      From the domains side, I can see http post in tcpdump
                                      Regards.
                                      • wlsdmsupport
                                        @wlcommunityusers
                                        This problem can be something according to your environment. Please follow below steps, if it is not going to solve your problem let’s have a teams support meeting.
                                        1. Add this JVM argument to WL-OPC.
                                          Open $WLOPC_HOME/bin/setenv.properties and apend the value to JAVA_OPTIONS parameter.
                                        -Dweblogic.security.SSL.minimumProtocolVersion=ALL
                                        1. Increase the timeout as below.
                                        2. Hard restart the OPC instance.
                                        $WLOPC_HOME/bin/opc stop
                                        $WLOPC_HOME/bin/opc start
                                        1. Then re-try adding the domain as I explained before.
                                        Kind Regards.
                                        • wlcommunityusers
                                          I’m still facing the same issue
                                          Handshake failed: SSLv3, error = No appropriate protocol (protocol is disabled or cipher suites are inappropriate)
                                          Handshake failed: SSLv2Hello, error = No appropriate protocol (protocol is disabled or cipher suites are inappropriate)
                                          Thank you very much.
                                          Regards,
                                          • wlsdmsupport
                                            @wlcommunityusers
                                            Hi ,
                                            Could you send us your WebLogic version, Adminserver and Managed Server JVM startup parameters, java version and java vendor please?
                                            Regards.
                                            • wlsdmsupport
                                              WLSDM Support @wlsdmsupport last edited by fevzi.korkutata-wlsdmteam
                                              By the way may be your WebLogic TLS version is legacy. Could you please let me know the WL-OPC’s JDK version with below command output?
                                              cat $JAVA_HOME/jre/lib/security | grep "jdk.tls.disabledAlgorithms"
                                              Send us the value of “jdk.tls.disabledAlgorithms”
                                              • wlsdmsupport
                                                After you have sent the environment details of your WebLogic and Java version we have realized that the client is legacy and we are compatible with TLS legacy Java version. We have detected the problem by reproducing in our LAB environments.
                                                Please add below JVM argument to WL-OPC setenv.properties file then bounce the OPC instance by using opc command executable.
                                                -Djdk.tls.client.protocols=TLSv1,TLSv1.1
                                                After restarting OPC please retry to add the client then let us know the result.
                                                Kind Regards.
                                                • wlcommunityusers
                                                  I added the argument to setenv, I send you the errors I have in log files.
                                                  Regards.
                                                  • wlcommunityusers
                                                    @wlcommunityusers
                                                    Regards.
